Use this task to configure IPv6 static routes for Management Instances.
For the Management Instance CLIP, you do not need to configure a default or static route. This interface type uses all routing information learned by protocols attached to the VRF. For more information about how to associate a VRF with the CLIP interface, see Configure a Segmented Management Instance.
For the Management Instance OOB and VLAN, you must configure a default or static route to reach the next-hop gateway; no routing protocol information is used to access off-link networks.
You can configure up to 100 IPv4 and IPv6 static routes.
- Expand Mgmt Instance.
- Select Mgmt.
- Select the Ipv6StaticRoute tab.
- Select Insert.
- For the Instance, select elect the type of Management Instance interface.
- Type the destination IPv6 address and prefix length.
- Type the next hop IPv6 address.
- Optional: Type a metric value.
- Select Insert.
Ipv6StaticRoute Field Descriptions
Use the data in the following table to use the Ipv6StaticRoute tab.
Name |
Description |
Instance |
Specifies the Management Instance. |
DestAddr |
Specifies the destination IP address. |
DestPrefixLen |
Specifies the destination prefix length. |
NextHop |
Specifies the next hop address for the static route. Use an IP address in the same subnet as the management VLAN IP address. |
IntfName |
Specifies the Management Instance interface name for the route entry. |
Metric |
Specifies the static route cost. The default is 200. The management CLIP uses an internal static route with a weight of 100. If you use both CLIP and VLAN and need to force all default traffic out the management VLAN interface, configure a default static route with a weight lower than 100. |
State |
Shows if the route is active or inactive. |
